Old 04-26-2017, 08:08 AM   #486
Heiko
Heiko's Avatar
Originally Posted by rczap View Post
Heiko, thanks for the help but neither code worked. Is there some other information that may help you find the correct one?
Rich
Rich
Using the serial you provided 'W5009183' the codes are 9947 or 9945 so can you double check your serial number using the menu on the radio.
Turn off radio.
Hold down the TP button for at least 10 seconds.
Turn the radio on. "Becker 1" will be displayed.
Rotate the right knob slowly, as it will display the Becker model number.
Rotate again and radio serial number will display on radio display.
If the serial number is still the same as what you typed then something else must be wrong...
Heiko
Previously owned:
