Old 04-21-2017, 09:33 PM   #3
particlewave
If the problem comes up again after replacing the check valve, I'm just going to remove the whole system.
I've just built a circuit that fools the DME during cold starts, so no ROW flash needed. The circuit is triggered by the air pump relay and just feeds a signal to the DME indicating that the required emission conditions have been met.
That will be the end of it and no pricey flash.
particlewave is online now   Reply With Quote
