Old 04-21-2017, 06:47 PM   #3
AZ986S
AZ986S's Avatar
Did you decide to go with a remote oil filter?
I'm debating if a shorty oil filter under the LN adapter then sandwich plate will work.
I also want to install it in the tunnel, since I don't like the trunk location generating heat in there...
There is a guy on youtube that did it on his 987 (tunnel mount).
2002 Boxster S - NHP 200 Cell Headers,test pipes,Borla CatBack,Competition Plenum,74 mm TB, EVOMS Tune,Tarett UDP,Eibach Swaybars,BIlstein PSS9s,TuneRS rear toe links,wheel studs,15 mm wheel spacers on all 4,EBC yellow stuff pads,Sebro rotors, EBS oil baffles,160 deg Thermostat,2 quart Accusump,full filtration remote oil filter,rad fan switch,custom gauge/switch plate, Race Capture data logging, 90K miles
AZ986S is offline   Reply With Quote
