Old 04-21-2017, 05:53 AM   #12
GaryMulcahey
Originally Posted by DrCactus View Post
Is it possible that my alternator is not charging the battery anymore? Is there a way to test alternator ?
If you take it for a drive, does it charge up the battery? Does the battery go dead if you are using the car a lot or just when sitting for a few days?
Take the car to your local and get them to test the system. Takes just a few minutes to put the gauges on it and find out if there is a drain or if your battery is need of replacing.
My system was pulling power when everything was off. The first season was not bad. It took a week or so for the battery to die. Last season it was over night. Like I said it was regulator/alternator.
1999 Silver Boxster
www.mulcahey.com
https://www.instagram.com/garymulcahey/
GaryMulcahey is offline   Reply With Quote
