Old 04-19-2017, 05:12 PM   #11
Lemming
Lemming's Avatar
Ok, wiring is down to where I want to go, got the essentials connected and the car turned over. I must admit, I was scared. I had the engine apart, so when I was cutting wires, I could not check to see if I had screwed up. Fuse box, relays, and alarm box are now on the passenger side. I need to clean up the wiring, seal cut ends, add mount relays for the lights and fans, and switches. That will be one good days work.
While I am waiting for electrical parts, pulled the front suspension to install the GT3 LCA'S, GT3 sway bars, and new wheel bearings (why not). Will start on the rear this weekend after spending two days at Barber watching Indy.
Tim
1998 986 (3.2L and 6-speed transmission added)
1999 986 (SPB)
1999 986 (parts car)
2001 986 S (parts car)
Lemming is offline   Reply With Quote
