Thread: Dome light 1997
Old 04-19-2017, 10:05 AM   #2
particlewave
Test between a solid ground and the positive voltage pin (red wire with black stripe). What's the voltage?
One ground is constant (a fixed connection to a chassis ground - brown wire) and is used for the operator switched on position. Test it against a good 12V+.
The other ground is fed by the immobilizer when either door is opened (brown wire with yellow stripe). Test it with door open against a good 12V+.
No fuse on the dome light circuit...
