Old 04-17-2017, 03:35 PM   #12
truegearhead
truegearhead's Avatar
KW confirmed all spring options are 30 days+ out so that's not an option. Tarret can over night me Swift springs which are 60mm in diameter (1mm under KWs) and are available in 450lbs and 500lbs (they may be able to get other rates I'll know tomorrow). I'm not sure what length will work with KWs and I'm not sure if KW shocks will handle that rate (I doubt it). The KW front rates are published simply as progressive but the rears are only 285lbs! What do you guys think? The car is under 2500lbs so the 450/500 rate is probably too stiff anyways. Think I would be safe with a 350lb spring? What would you go with? Any ideas what length I should get? If the car weren't in a shop an hour away getting a roll bar installed I'd go measure.
Cheers,
1997 Boxster 4.2L Audi V8 Bi-Turbo
2003 911 C2
NASA HPDE Instructor
truegearhead is offline   Reply With Quote
