Old 04-17-2017, 10:02 AM   #4
JFP in PA
Originally Posted by PBoxstar View Post
Hi All,
My 99 Boxster 2.5L is unhappy and throws DTC P0446 ("Evaporative Emission System Vent Control").
I researched the issue for a while and decide to take a look at the Evap system by the tank filler neck.
Here is what I found out so far:
The valve attached to the carbon canister seems to be working, I removed the valve and applied 12V and Ground to the two leads. The valve actuates and closes the plunger/diaphragm. Are there any other things I should check?
I also removed the other valve which was attached to the filler neck (see below).
When I blow in the red part (green arrow), the air flow is blocked. Once I push in the black plastic piece (yellow arrow) air can flow through the valve from green to green arrow. I assume that is correct behavior.
While I was on it I also removed the carbon canister. I can blow air through the hose (from green to green arrow) so it doesn't seem like there is blockage in there either...
How can I debug the actual carbon canister?
All of the other hoses are attached to the vehicle and lead to and from the tank I presume...?
What else can I do to debug the fault? I'm kind of running out of ideas....
Any help is appreciated at this point!
You are at the wrong end of the system, the purge valve is under the intake manifold:
