Thread: Say YES to MAF!
Old 07-27-2006, 10:34 AM   #12
MNBoxster
Originally Posted by CJ_Boxster
When do O2's eventually go bad and trigger the CE light? I have 94k on my Box and o2's seem fine....I was thinking since they are not bad and possibly replace, is it ok to remove them and clean them up and reuse them? My father used to do that when he was a mechanic and it seemed to help alot and would turn off CE lights.....So question is, if my CE light isnt on yet, would it hurt for me to try and clean my o2's before they go bad?
Hi,
I would not recommend it. The potential to create a problem is too great. At 94k mi., the wiring is likely to be brittle from Heat Cycling, or you could cause internal damage in trying to remove them - you could actually cause a malfunction.
I'd recommend leaving them alone until you get the CEL and then try cleaning them, worse case, you have to replace them, but not prematurely. Hope this helps...
Happy Motoring!... Jim'99
