Old 04-15-2017, 03:12 AM   #20
cnavarro
Originally Posted by Cbonilla View Post
Here is how my shop responded. I'd welcome your informed views
Basically, the tool that LN Engineering sells you to install the “superior” bearing is not very good (and yes, we do have the newer bearing tool). We have installed a couple of the “Single Row Pro” kits on cars and had some issues with the tool and fitment in which we didn’t feel comfortable with either the installation process or with that tool. Additionally, there is a very fine (thin) lock ring wire which that tool installs with the bearing that is impossible to tell if it has seated properly. The bearing may have more load capacity and a longer service interval but if it doesn’t install correctly that really won’t matter. We like and trust LN Engineering and their products as theirs is the only replacement IMS bearing that we will sell and install. The “Single Row Classic” bearing is of a better design and material than the stock bearing and we feel it will go farther than the suggested 4yrs, 50,000 miles given the fact that there are a larger percentage of cars on the road still with the stock single row bearing that have exceeded that mileage range and time window without failures. We feel that the suggested time and mileage from LN Engineering is to their benefit, same goes for the limited warranty. ... I might add that most, if not all, Porsche dealerships won’t install that bearing either choosing instead to install Porsche’s own bearing which is of the single row design.
I chose to raise the missing sticker in my response to this email, so it could not have been addressed here
We have received a few complaints on the Faultless Tool that have been unfounded. Jake designed the tool and I made it - and it works. Just like the Faultless Wrist Pin Tool. Some shops just want the easy way out. They probably don't even have the tool or they didn't read the step by step printed manual that comes with it.
I also find interesting that they say most dealerships choose to install Porsche's own bearing. Interesting because so such option exists. In fact, dealerships were the first to buy our kits because they knew the IMS was a real problem.
Charles Navarro
President, LN Engineering and Bilt Racing Service
http://www.LNengineering.com
Home of Nickies, IMS Retrofit, and IMS Solution
cnavarro is offline   Reply With Quote
