Old 04-14-2017, 07:29 AM   #146
BRAN
WALDMEISTER
BRAN's Avatar
Alright...so there still is detail work to do, before bringing it to the paint shop!
I noticed, that the side windows lift the roof when fully closed, just 1mm but noticeable, on both sides without the rubber seal. Sanding might do the trick.
I loosely put the trunk lid into place to see if the weight pushes the TOP a little more down.
Left side yes...with sanding and adjustments i might get a properly leveled gap.
Right side NOPE. It still sits 2mm too high, so the gap is not properly leveled. Anyone ran into the same problem while installing the Z-Top? Hints are welcome
If I can't fix it, I gonna let the paint/body shop guys try their luck
It starts to shape up
