Old 04-14-2017, 04:14 AM   #2
KevinH1990
KevinH1990's Avatar
Check the Pelican Parts web site. There is a DIY for installing full power seats: Pelican Technical Article: Installing 997 Seats Into a 986 Boxster
According to that article, they should just bolt in. The article also describes the wiring, but yours should be much simpler because they are two-way seats, not full power.
The clearance issue for the back support is not discussed in the article. You may just need to take the plunge and see if there is a problem.
I may be undertaking a similar project with full power heated seats, so please post anything you learn.
Good luck.
