Old 04-13-2017, 03:23 PM   #25
Boxtaboy
07 Carrera S Cab
Boxtaboy's Avatar
Bullshyt
A good shop absolutely should be recommending and discussing with you the options and what they feel is the best option for your needs
They should tell you exactly what they will be doing and what parts they will be using. Using your example of an oil change, they must ask and let you know the options and what oil they will be putting in
The ultimate decision is yours, not the shop
Case in point
I just had a torn CV boot and my mechanic gave me 3 options
1- replace the boot and rebuild the CV
2 - replace the axle with an aftermarket one
3 - replace the axle with a factory one
He gave me the costs ans well as the pros and cons of each choice and I decided on how I would spend my $$
No, your whole assumption is that he went to a good shop. If so, then yeah, those things apply. The shop still did install a LN bearing as instructed. It just didn't act as a good shop in good faith to ask him if he wanted the pro bearing installed.
