Originally Posted by husker boxster
Put the CPS back in, started right up. Took her for 10 mi drive this morning and parked in the garage. Waited 30 min and she started right up.
I hate intermittent problems. Still no codes on my reader.
Refill a full one with fresh gasoline? Season/temp change = condensation. High risk for a garaged car that occasionally goes in/out and is not driven often. Although I do not recommend you to run the car if indeed you do have water contamination, could be different for a Honda mind you.
If the case, water needs to be taken out. Bet there are tons of comm products available to deal with this problem.
Wild guess there, g-luck
