Old 04-13-2017, 12:41 AM   #21
particlewave
Something I've considered to simplify things a tiny bit is eliminating the vacuum and electronic changeover valve. As it is, the system requires air pressure, electricity and vacuum. Why not just feed the electronic changeover valve signal to a relay that powers a solenoid operated changeover valve?
I may try this...
I'm doing this.
I just ordered a solenoid valve for $5...if it doesn't work out, I'm not out much. But it will work great.
I'll be happy to eliminate vacuum from the system and lose the electronic changeover valve. Vacuum sucks (pun intended ).
