Personally, I chose to have the metal pipes modified, however it doesn't look like the shop that offered that service is still around. You should be able to add a Tee to the existing hose for the center radiator, it would certainly be the easiest and cheapest solution, however you would be introducing a potential weak spot. Someone in the thread I linked to mentioned they did it this way and it worked, but they did not like how it turned out.
