Old 04-10-2017, 12:30 PM   #3268
Cbonilla
Decided to repost not using the paperclip icon at the top of the dialogue box and instead use the "attach a photo" link that promises to resize my pics and hopefully let me place them in the right place in my text.
Refinished my BBS Sport Design wheels with Duplicolor spray cans.
Partially refinished I should add, because the wheel centers were in OK condition, far better than the perimeters. These are BBS Sport Design wheels, all of which seem to suffer from corrosion in the finish on the perimeter of the rim. My sense is that this arises because the wheel centers do not perfectly seal on the rim (they don't need to actually) and let cleaning agents drip out over time long after you think that you've rinsed it all off, and proceed to eat up the finish. My belief is reinforced by the fact that the damage was not uniform and instead was localized. Moreover, on one occassion when a zealous detailer used some strong chemicals, the next morning I could see bubbling in the finish of all the wheels at the 6:00 position.
I know that the proper way to do these is to remove the 20 titanium bolts and take each wheel apart. This was more than I wanted to undertake, and I know that if you do this you run the risk of snapping off a bolt (they are set with Locktite), hopefully leaving enough of a stub to get a grip on them and still remove them. Instead I carefully hand sanded the perimters. Used 150 wet or dry sand paper followed by 220 and 400.
The first picture is my wheels before this work.
Here is what they looked like after sanding. My goal was to remove the visible corrosion completely and then abrade the remainder to provide a tooth for the new finish. Hopefully without damaging the finish on the centers as I they were in OK shape.
I know the wheel centers don't look that great in the before pics. They are just dirty and clean up quite well. See the "finished" picture
Next pic is the wheels after sanding
After a thorogh cleaning and allowing them to dry in the sun, I masked the wheels using index cards between the wheels and tire, blue painters tape between the two parts of the wheel (trimmed with a razor knife following the seam between the two parts of the wheel) and a damp folded towel over the centers.
Important: You remember how I talked of how cleaners slowly leaked out throught the wheel seams? I used an aircompresser to blow the water out of that seam after letting the wheels dry in the sun. Without the air compresser water would have continued to slowly dribble out onto the finish before it was fully cured. The damage at the 6:00 position that I noted earlier was the morning after a detailer cleaned them followed by a 40 mile drive.
Finally the finished wheel perimeter. That was after 3 coats of Duplicolor self etching primer (DAP 1690), four coats of color (HWP101 Silver) and three coats of Matte Clear (HWP106)
I did both wheels on one side working from noon to 7:00 PM. We'll see how they hold up over time, but for now I'm pleased. My expectations for this project were far exceeded. My initial goal was for them to be just "better." I would say that the are 90-95% - pleasantly surprised, both in the quality of my work and how well the Duplicolor matched the finish on the wheel centers.
Two down, two to go.
Cbonilla is offline   Reply With Quote
