Old 04-09-2017, 12:25 PM   #13
particlewave
Looks like healthservices already drew up a diagram
In his diagram, where it says "to aftermarket keyless signal wire", attach your purple wire from the keyless entry module.
I'd do what he did and mount the relay in the trunk, right next to the actuator. This seems easiest.
You'll cut the blue/black wire in 2 places: at the immobilizer where you'll connect your purple wire, and at the actuator, where the blue black/wire coming into the trunk will now be connected to your relay (pin 85), and the switched ground from the relay (pin 87) will be connected to the blue black wire on the actuator.
Originally Posted by healthservices View Post
try this one instead...
87 jumps over the red wire it does not connect to it.
particlewave is online now   Reply With Quote
