Are both fans running? Just turn on the AC and both fans will come on. If not, then either the fan or the resister ballast is bad. The relays are very stout on these cars so I don't think it is a relay. I just changed the resister ballast on the right side as I was noticing the temp higher than normal. When I got home I noticed the right fan not running when the AC was on. Crawled underneath and could see the ballast was corroded and part of the housing gone. A new one will run you about $120-140 depending on where you buy it.
1999 996-Carrera Arena Red Metallic-Current
1998 Boxster-Glacier White-Sold
1997 Boxster-Ocean Blue Metallic-Modified-Sold
