That tool looks very beefy, bird dog!
Here's my harbor freight balljoint tool, with inside u-shaped edge ground out to fit around the 986 balljoint's 26mm diameter. (Still works on 986 tie rod ends, too!) I have very little doubt that this tool will also last my lifetime.
If you only back off the nut a little bit, the joints will pop loose with yawn-worthy drama.
