The key to making a pickle fork and BFH work is the ability to impart a SOLID impact to what you are abusing. Unfortunately as you know trying to get a solid impact when the car is on jack stands and the carrier hanging is everything moves when you hit the pickle fork. This absorbs most of the impact. Do you have ramps or some blocks? Try putting the wheel back on and set the car weight back on it. This will make a solid base so the parts will not move and the impact will have a lot more IMPACT.
