Piece of cake. Pull the trim plate off the seat. Release the 4 catches that hold the switch to the plate.
Inside you see the contacts. There will be black soot on the points. Remove the grey rocker and then the 2 points assemblies. Clean off add some new dielectric grease and reassemble.
