Originally Posted by itsnotanova
Who did you get it from? It's getting blocked and comes out as (**********az)
Not sure why it's getting blocked, but it was "Auto-haus-AZ".
In my mind, if you're in that business, you need to properly vet your suppliers, that's if you want a good reputation... I've had a good experience with all the other stuff I've purchased from them, just this last one...
2002 Boxster S - NHP 200 Cell Headers,test pipes,Borla CatBack,Competition Plenum,74 mm TB, EVOMS Tune,Tarett UDP,Eibach Swaybars,BIlstein PSS9s,TuneRS rear toe links,wheel studs,15 mm wheel spacers on all 4,EBC yellow stuff pads,Sebro rotors, EBS oil baffles,160 deg Thermostat,2 quart Accusump,full filtration remote oil filter,rad fan switch,custom gauge/switch plate, Race Capture data logging, 90K miles
