easy fix
This happened to mine as well. The solution is adding some good thin 2 sided tape under the rubber strip.
I assume the "additional cloth strip" is not even from side to side? Mine sort of pulled up a bit in the middle and made the back window flutter on the highway. The rubber strip holing that on just pulls off and the top has to be pulled down tight pressed onto the new tape and rubber strip reinstalled to hold it tight. You might get away with just doing the middle third of the window like mine. I think I did it with the top partly open to release pressure.
It's a fiddly job that might require a third hand. An upholstery shop could probably fix it in an hour or so.
