Old 04-03-2017, 06:34 AM   #1
78F350
Motorist & Coffee Drinker
78F350's Avatar
Since nobody else jumped in yet, I'll give it a shot...
The IMS bearing sits in the IMS and does not directly seal to the case. A leak to the outside of the engine would have to be from the flange seal or o-ring for the center bolt - not through the bearing itself. I had that happen on one of my '99s, so I had the whole bearing replaced as a 'while you are in there' even though there were no signs it was bad.
For the RMS, here's some Renntech:
https://www.renntech.org/forums/topic/46391-installing-rms-without-porsche-special-tool-9609-96061/
https://www.renntech.org/forums/topic/46156-rms-seal-replacement-at-45k-miles/
Note the bit of discussion about the new (PTFE) seals install 13MM from the flywheel mating surface of the crank, not 14MM
