Old 04-02-2017, 02:39 PM   #1
sfkjeld
sfkjeld's Avatar
Thanks NewArt. After unsuccessfully trying to locate the control arms to the clamshell while down, decided to try to help by manually pulling the top back with the motor. Et voila, the clamshell popped up and the top fell into place. Need to investigate lube points next.
The remaining problem tho is that the top appears all the way down, but the red warning light for the top is on. Also noticed the windows will not come all the way up now.
Nothing's easy, huh?
sfkjeld is offline   Reply With Quote
