Originally Posted by BoxsterLS376
Ahh ok my bad. Are you trying to get the traction control working or something? Not sure why you need the GM ECU to see the ABS stuff otherwise. Almost sounds like you are trying to get the speedo to work, which in that case I can't really help either as the Boxster picks up the speed from a plug on the transmission. Does the 911 pick up speed from the ABS?
Regarding the ABS signal stuff - The short answer to your questions is unfortunately no. Google was my best friend during the build but that was not something I ever dealt with, sorry.
J
Need the vehicle speed for emissions drive cycle tests .The ecu needs to know the car is moving The 996 abs right rear wheel sensor is used for the vehicle speed signal .The abs control unit does something to that signal .Don't know what and so far google doesn't know either .
Thanks for the speedy responses
