Old 04-01-2017, 02:19 PM   #504
BoxsterLS376
Originally Posted by dcdrechsel View Post
Boxster ls376 -knew about the tach -was hoping you had connected the vehicle speed input from the abs to the gm ecu .The fundamental issue is what are the abs vss signal characteristics ?Once that is known should not be hard to convert to gm specs .
Perhaps you could point me to some likely sources to figure out what that signal is ?
Ahh ok my bad. Are you trying to get the traction control working or something? Not sure why you need the GM ECU to see the ABS stuff otherwise. Almost sounds like you are trying to get the speedo to work, which in that case I can't really help either as the Boxster picks up the speed from a plug on the transmission. Does the 911 pick up speed from the ABS?
Regarding the ABS signal stuff - The short answer to your questions is unfortunately no. Google was my best friend during the build but that was not something I ever dealt with, sorry.
J
John or J.J. - But I answer to most anything~
*2000 Honda Accord 4DR V6 - 220K*
http://986forum.com/forums/show-tell-gallery/54328-boxsterls376-introduction-ls3-conversion.html
BoxsterLS376 is offline   Reply With Quote
