Boxster ls376 -knew about the tach -was hoping you had connected the vehicle speed input from the abs to the gm ecu .The fundamental issue is what are the abs vss signal characteristics ?Once that is known should not be hard to convert to gm specs .
Perhaps you could point me to some likely sources to figure out what that signal is ?
