Old 03-30-2017, 12:17 AM   #138
particlewave
Yes. Green wire to top right pin, orange wire to switched 12V+.
Tapping the green wire to that pin will dim the DRLs when the headlight switch is in any on position (parking lights or headlights on). Tapping it into the yellow/black wire that you already tapped will dim them only when the headlights are on (DRLs at 100% with headlight switch off or in parking light position).
If you're still not getting 12V+ on the yellow/black wire (bottom right pin), then your fuse is probably blown again.
