Old 03-29-2017, 11:11 AM   #1
A6P
A6P's Avatar
Revived White 986 after 10 years of sitting
so i had this car in my house for a while now around 10 years now and hadnt had the time to fix it from working so much, finally got around to it.
i towed the car to my shop, car was not getting any fuel, so i changed the fuel pump, cleaned out the gas tank completely.
I decided to do little maintenance on it since its been so long, changed the spark plugs, air filter, oil change (mobil 1).
car ran at this point but was hesitating, so i changed the MAF sensor and problem was fixed.
then i realized the key would be out of the car but the dash lights would not go off and the car would ring when the door was open, so i changed the ignition switch first since its cheapest to start with and after that worked perfect.
when i got this car it had the radio stolen from it, so i decided to change one with a screen and navigation even tho i never use it.
then I changed the shift boot leather since it was very worn out, and decided why not the center armrest compartment lid as well. why not since car only has 49,000 miles on it.
Repainted the Calipers and put in some new Rotors and painted rims gloss black as well ( paint is peel-able and no its not plastidip as you can see its very glossy.)
tinted the taillights and side markers as well
the rear window vinyl was a disgusting yellow color so i replaced that as well. so car is running perfect as we speak!!
p.s idk why images look like crap... sorry in advance
also this is my first post, idk if it was suppose to be on general posts or show and tell.... so mods change it if its wrong.
A6P is offline   Reply With Quote
