Old 03-28-2017, 10:45 AM   #1
Coaster
Coaster's Avatar
FYI: all of the Audi relays I found were $75-$100, and you still have to do a lot of wiring.
You could save yourself some trouble and just buy a plug-and-play one touch flasher relay. I've seen them for around $50, but I'm sure they can be found cheaper.
No need to do all that crazy wiring. Just pop in the relay and you're done.
I bought my kit for $51, They had to move 5 wires from the switch to the new switch and it integrates in the emergency flasher harness.
2003 S, 6 Speed, PCM, PSM, Bose, Litronics with washers, on its' second LN IMSB, comfort top, UDP, 987 engine mount, 997 RMS, Koni Sport Shocks, H&R springs, Techno brace, comfort blinkers, nin8six windscreen, particlewave light up cubby
Coaster is offline   Reply With Quote
