Thread: The not quite S
Old 03-28-2017, 08:09 AM   #18
The Radium King
The Radium King's Avatar
i think you need:
- shift cables
- transmission mount brackets
- slave cylinder and piping to the bulkhead (can't just change the slave cyl unless you want to customise fittings)
- 5-speed axles will work with 6-speed wheel carriers - you need 5-speed hubs to match the diameter and spline pattern of the axles; the bigger 'S' wheel bearings mean you get just enough thread for the axle bolts
- swap transmission flanges - not sure? there is some stuff on the net about this, but seems like a lot of work; i'd run it until (if) it breaks then deal with it at that point
