Old 03-28-2017, 12:27 AM   #129
itskenallen
itskenallen's Avatar
Originally Posted by oldskool73 View Post
"The switch live in my headlights is the grey wire with a black strip, when connected to that I have only 50% power in the DRL's. Fml " ... isn't that the point of that wire? Your DRL controller looks like one of the auto sensing ones that turns itself on and off via the battery voltage. That extra wire is to dim the DRL's when the main lights are on. If you don't want that to happen, just don't connect that wire... though MOT rules might require them to dim when the lights are on?
Problem is they're not lighting fully at all, even with the ignition on and the headlights off.
itskenallen is offline   Reply With Quote
