Thread: Idle issue
Old 03-27-2017, 02:05 PM   #7
mikefocke
Is the MAF the correct part? There were some changes where the ECU had to be flashed if you got the updated part.
Have you driven the car through enough cycles for the ECU to relearn?
How long was the AOS bad and how much damage did the CATs and O2 sensors take?
Have you cleaned the throttle body and air intake of oil from the prior failure?
