Old 03-27-2017, 09:43 AM   #124
itskenallen
itskenallen's Avatar
Replace the fuse and try again.
That wire from the DRL controller is signal only, so will not increase the load enough to blow a fuse. Make sure you're using the correct controller wire and that nothing is shorting to ground.
To answer your question, no. The headlight dim circuit has a high rating.
Excuse my ignorance but I'm either really thick
Or I'm not understanding you.
In the diagram above, what wire do I connect the black wire coming from the controller that says "headlight /dashlight"?
The switch live in my headlights is the grey wire with a black strip, when connected to that I have only 50% power in the DRL's. Fml
I have the 2 DRL's wired together ( red to red and black to black) and then run to the controller.
Sent from my SM-G928F using Tapatalk
itskenallen is offline   Reply With Quote
