Old 03-27-2017, 08:44 AM   #123
particlewave
Replace the fuse and try again.
That wire from the DRL controller is signal only, so will not increase the load enough to blow a fuse. Make sure you're using the correct controller wire and that nothing is shorting to ground.
To answer your question, no. The headlight dim circuit has a high rating.
