Particlewave have I the right wire in the front passenger side (drivers side US)? I tapped into the yellow/black, connected to the relay for the DRL'S and I have no dims on that side only since. Checked the voltage with the engine running and nothing. I do however have 13V in the top right hand pin as you're looking at it.
Edit.. Blew the headlight dim fuse.
OK.. So which wire do I use now.
As these headlight wires are very awkward to tap into is there any other wire I could use that's easily accessible?
Sent from my SM-G928F using Tapatalk
