Old 03-26-2017, 06:41 PM   #13
Chuck W.
Chuck W.'s Avatar
Originally Posted by Javi Cooper View Post
What year is your Boxster and what year 996 cluster did you use? Did you have to reprogram the cluster as mentioned in the article (that's the part keeping me from pulling the trigger)? I also see that you reprogrammed the mileage - who did you use and how much was it? And finally, did you use a cluster off a cabrio? If not, did you also reprogram the cluster for the convertible lamp to work? Thanks.
My Boxster is a 2001 and I used a 2003 cluster. I did not have to reprogram the 996 cluster. It was from a cab so that light works. The 996 did not have PSM so the two PSM related lights in the cluster do not light up. I'll have my mechanic active them next time it is in for a service. If the 996 cluster wasn't from a cab it would have been the same thing. As far as having the mileage reset I used ODO-Pro.com. They charged $89 with free return shipping. I extensively documented and photoed the swap so there would never be a question on the Boxster's true mileage.
Pelican has a great article on the swap;
Porsche Boxster 996 Gauge Cluster Upgrade - 986 / 987 (1997-08) - Pelican Parts Technical Article
1995 Porsche C4 Cab
