Old 03-26-2017, 08:10 AM   #1
Gilles
2003 and new Boxsters do not have removable plug tubes, they metal and cast into the cam covers.
Yes, you have three green seals that sit between the head and the inside of the cam cover:
Also, as a precaution I decided to replace the o-rings on both cam actuators and used the sealant sold by Pelican for the cam cover, and so far (after +/- 1,000K) have not got any more leaks :-)
However, I lowered the engine a few inches for the cam cover to clear the frame.
I can search the P/N's for the seals I replaced if you need them.
Good luck!
PS: the two other holes on the left side are where the variocam actuators go
Gilles is offline   Reply With Quote
