Old 03-24-2017, 07:15 AM   #1
itsnotanova
I get why you would want OEM. Usually the aftermarket is of less quality. I think you should give the aftermarket a chance for two reasons. 1) of the 03-04 tops I've come across, most had a wear problem just like Kevin's has. Something about the way they fold or something rubbing on the inside causes them to develop a hole right there on the sides. Most likely anything you find will also have that problem starting. 2) Every canvas replacement I've seen has been pretty good quality. Granted I've only seen replacement tops for the 97-02 with a plastic or small glass window and not a replacement glass top for the 03-04.
Woody
