Yup, thats the bolt had problem trying to remove because the eccentric washer is stuck to the bolt.
The last time I test drove the car, the back was push to the left.
I jusst went out to check the eccentric and it is still tight after I last tighten it..
But now it was the bolt from the front track arm to the wish bone which loose. Tighten it and will test drive shortly. fingers crossed.
