Old 03-22-2017, 09:24 AM   #3
particlewave
Originally Posted by Burg Boxster View Post
Suspect your issue may be related to the LEDs you have installed and their lower resistance. Did you add an resistors to the equation when installed?
The side marker circuit (front, rear and fender) does not require LED load resistors.
Originally Posted by 986ohana View Post
No I didn't, I suspected it was built into the unit it self!
Can you help by telling me how to go about it myself, what if I changed everything to LED
Check your DRL relay.
particlewave is online now   Reply With Quote
