I would make a point of changing the bearing out if your inention is so keep the car long term. The IMS Solution is a $1725 kit and the labor can't be $2275 to do the install. I have done the change, not with this kit and the labor seems quite high. You should get an itemized estimate for the work. The 30% comment is also quite a bit higher than reported....
______
Jon
1966 912, 1976 911
1986 944, 2000 Boxster
