Originally Posted by moosport
I'm having issue trying to tighten the inboard rear wish bone bolt. It keeps breaking loose during test drive. The suspension was loaded when tightening the bolt.
Thoughts?
I guess first question, is the bolt you are referring to the one with the eccentric head and washer used to adjust camber, and is it intact? The bosses the eccentric heads butt against intact? Or has someone replaced with a plain bolt and washer?
