Old 03-20-2017, 04:51 PM   #18
Dr. Acula
Dr. Acula's Avatar
The 9A1 engines do not use a simple thermostat like the M96/97, they have a more sophisticated "thermal management system" which is electronically controlled. Would they benefit from running a bit cooler, sure, but how to do it becomes the issue.
Good info to know, thanks! Along those same lines, then, do you have an opinion on the third radiator kit for the non-PDK 9A1 cars?
I have a 2011 Boxster S and I monitor the coolant temp with an OBD-2 Ultragauge. The coolant temps in this car vary as much as 20 degrees just driving around town, It freaks me out because my Toyotas don't vary near that much.
Dr. Acula is offline   Reply With Quote
