Old 03-20-2017, 04:08 PM   #11
Jamesp
Beginner
Jamesp's Avatar
Originally Posted by cornontherob View Post
Got the panel off, started the car and confirmed that it was still doing it. Took off the belt and started again for a couple seconds and the problem was gone. It looks like the pulley on the alternator bolt had seized up and melted the belt to it, which explains a lot. Ordering a new pulley, bolt, and belt. However, I have no idea how to get the old idler pulley out without removing the entire alternator, which is an utter drag. Any ideas?
if you are talking about the idler pulley just to the right of the alternator pulley, you'll just need to pull the center bolt. You'll get the bolt, a washer and a spacer along with the pulley. They all need to go back the same way.
2003 S manual
