Old 03-20-2017, 03:15 PM   #108
particlewave
Originally Posted by itskenallen View Post
Nice one Particlewave. That would explain it. Going by your picture above, I pulled relay 19.
So, any ideas?
Sent from my SM-G928F using Tapatalk
Do you just want the fog lights on at all times when the ignition is on?
If so, pull the headlight switch and connect a jumper wire between the violet wire and the yellow with white stripe wire, which are both on the headlight switch connector (back of switch - do not sever them from the switch, just jump between them).
That will do it on UK cars.
