Old 03-20-2017, 02:10 PM   #7
The Radium King
The Radium King's Avatar
belt pump is rpm sensitive so required if used in a supply situation i think (faster engine needs more oil). for scavenge then electric is fine, as long as it can scavenge faster than the max supply rate. internal oil pump capability is a concern, but keep piping short and put reservoir higher if uses as supply / lower if used as scavenge and no head issues.
