Old 03-20-2017, 11:50 AM   #4
Gilles
Originally Posted by Mr Flat Six View Post
Thanks JayG. I have looked at many DIY including the Pelican one. A lot do this with the hoses removed. I just wanted to be careful before bending the hose so much.
If you already removed the center cover you will see the bracket that holds the two cooling hoses on the center tunnel, by removing this bracket you will be able to separate the hoses from each other and you will have enough space to remove the engine support.
Good luck
